vilo 440 ci 71
vilo 440 ci 71
Messagepar fred jensen » 29 Aoû 2014, 14:02
bonjour a tous,je vais rectifier mon vilo ,est il nescesaire de le faire equilibrer,je precise que c'est un vilo forgé external balance ...
fred jensen
Images: 1
Re: vilo 440 ci 71
Messagepar phil64 » 29 Aoû 2014, 15:06
Bonne question, je n'en sais rien !!!! En effet "external balance" signifie qu'il est équilibré extérieurement D'après ce que je lis ici il faut bien l'équilibrer mais l'équilibrage se passe avec les "pièces" qui participent à "l'external blance" c.a.d. le damper ou le volant
When the counterweights alone can be made to balance the crankshaft, the crank is said to be "internally balanced". If the counterweights are too light by themselves to balance the crankshaft and more weight is needed, an "external balance" can be used. This involves a harmonic dampener or flywheel that has a weight on it in the same position as the counterweight that effectively "adds" to the weight of the counterweight on the crankshaft. Since the harmonic dampener (front) or flywheel (rear) play a part in the balancing of the assembly, they must be installed on the crankshaft when it is balanced. This is unlike an internal balance configuration where the harmonic dampener or flywheel do not contribute to the balance of the crankshaft and are not required to be installed when the crankshaft if balanced. Both methods are used from the manufacturer. An example of some factory internally balanced engines are Chevy 305 and 350 (2 piece rear seal only!), Chevy 396/427, GM LS-series, and Ford "modular" 4.6. Some examples of factory externally balanced engines are Chevy 400 and 454, Ford 302 and 351W. Some engines are even a combination of both: being internally balanced in the front and externally balanced in the rear! The most common example of this is the Chevy 350 (1 piece rear seal) including LT1. Regardless of how an engine is balanced from the factory any balancing method is acceptable as long as the required harmonic dampener and/or flywheel is available.
